Beginners question in multiple assignments to output
- 3 years ago
What you seem to be asking for is analog logic, summing the levels on two wires to produce an output signal that can have three discrete levels.
IE: (0,1) + (0,1) = (0,1,2)
This is not possible in digital logic FPGAs.
At best you could two outputs and resistors to simulate a simple digital to analog converter, much like some development boards support an analog VGA signal using an array of resistor values R-2R-4R-8R etc to make a simple D to A.
Can't be done internal to a device however. Not with any current Altera FPGA parts AFAIK.
Hi FPGA_FR,
May I know if there is any update from previous reply?
Dear SyafieqS,
I have received an answer from ak6dn, which is ok with me and make sense.
Also, would it possible as a moderator that you are not using my first name from my account information but my username FPGA_FR in public post ? Is it possible to edit that out from your previous message ?
Thank you very much for your understanding on this matter.
Thank you all for your help on this forum.
Very much appreciated
Best wishes,
