Beginners question in multiple assignments to output
- 3 years ago
What you seem to be asking for is analog logic, summing the levels on two wires to produce an output signal that can have three discrete levels.
IE: (0,1) + (0,1) = (0,1,2)
This is not possible in digital logic FPGAs.
At best you could two outputs and resistors to simulate a simple digital to analog converter, much like some development boards support an analog VGA signal using an array of resistor values R-2R-4R-8R etc to make a simple D to A.
Can't be done internal to a device however. Not with any current Altera FPGA parts AFAIK.
