autoboot of UP Linux image on DE1-SoC fails
Re: autoboot of UP Linux image on DE1-SoC fails
The problem is not due to writing the SD card with dd, that's OK. It rather seems to be a preloader problem, in this version of the UP Linux image. I found the previous Image build as of October 18, 2016, at https://xdevs.com/doc/ALTERA/Terasic_DE1SoC/DE1-SoC-UP-Linux.zip that boots successfully. A comparison of the U-Boot startup sequence output in the PuTTY terminal in this case, with that reported for the newer Image, may suggest something about the possible preloader problem with the latter:
U-Boot 2013.01.01 (Apr 25 2014 - 04:59:35)
CPU : Altera SOCFPGA Platform
BOARD : Altera SOCFPGA Cyclone V Board
I2C: ready
DRAM: 1 GiB
MMC: ALTERA DWMMC: 0
In: serial
Out: serial
Err: serial
Net: mii0
Hit any key to stop autoboot: 0
reading uImage
4315040 bytes read in 385 ms (10.7 MiB/s)
reading socfpga.dtb
19147 bytes read in 7 ms (2.6 MiB/s)
reading soc_system.rbf
2316870 bytes read in 209 ms (10.6 MiB/s)
## starting application at 0x3FF7D4F8 ...
## Application terminated, rc = 0x0
## Booting kernel from Legacy Image at 00007fc0 ...
The kernel startup runs fine, but the following output is perhaps relevant to the subject problem, since it relates to mounting the SD card:
[ 2.270471] EXT3-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (240)
[ 2.281243] EXT2-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (240)
[ 2.308475] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. opts: (null)
I wonder whether the preloader in the newest version fails because of inability to recognize the filesystem type (ext4) mounted in the Linux partition.
