16 years agoAudio UP 9.0 Problem
Hi, De2 board.. I'm trying to feed the buffers with; writenR= alt_up_audio_write_fifo (audio_dev, buff_pointer, 1800, ALT_UP_AUDIO_RIGHT); writenL= alt_up_audio_write_fifo (...
16 years agoThis is the clock that must loop-back to the Nios Master clock
In your scheme the sys_clk must drive only the ext_clk_50_to_de_boards_0 and the sys_clock_from_de_board_0 must be connected to clk_0.
