16 years agoAudio IP Core Help
I am in the process of attempting to use the Audio IP Core to take input from the Mic, and then output it the Line out.
I have created a system in the SOPC builder with the following components: cpu_0 onchip_memory2_0 PIO(Input) PIO(Output) audio_and_video_config_0 audio_0 For the audio_and_video_config_0, I've set it to initialize both Audio and Video. I've set the In path to Microphone to ADC, and Out to enable DAC. This will build without error. I have the following C application to run on this system just to verify the Audio I/O is working. # include <system.h># include <altera_up_avalon_audio.h> # define Switches (volatile char *) SWITCHES_BASE# define LEDs (char *) LEDS_BASE # define BUFFER_SIZE 512 void increaseGain(unsigned int *buffer, unsigned length); int main() { alt_up_audio_dev * audioDev = 0; unsigned int buffer[BUFFER_SIZE]; unsigned length = (BUFFER_SIZE/2); int readData = 0; //Open the Audio device audioDev = alt_up_audio_open_dev(AUDIO_0_NAME); //reset the Audio Device alt_up_audio_reset_audio_core(audioDev); while (1) { *LEDs = *Switches; readData = alt_up_audio_read_fifo(audioDev, buffer, length, ALT_UP_AUDIO_LEFT); alt_up_audio_write_fifo(audioDev, buffer, readData, ALT_UP_AUDIO_LEFT); readData = alt_up_audio_read_fifo(audioDev, buffer, length, ALT_UP_AUDIO_RIGHT); alt_up_audio_write_fifo(audioDev, buffer, readData, ALT_UP_AUDIO_RIGHT); } return 0; } Right now when I download my image, the mic in, is automatically playing out the Line out, however it's very quiet and distorted. Any assistance is appreciated.1 Reply
hi!
i m sorry i cannot answer your question, but can i thinku can help me as i m working on a similar project... where should i copy the header file to avoid the long include statement like "c:\dir1\dir2\include\altera_up_avalon_audio.h" or is it possible to do the same in NIOS2 IDE somehow?
