9 years agoAudio Core IP with ST interface: Clock setting
Hello everybody, this is my first Problem Report in this FORUM :D So... I'm trying to use the WOLFSON Audio CODEC on DE2 board to output an audio stream (96kSamples/sec) generated by Custom H...
9 years agoHello Lucazambuto,
Your board is supplied with demo examples (cd or via Terrasic.com) You might want to take a look at them (DE2_115_Synthesizer). It is much easier to start from a working example then to build your application from scratch. Best Regards, Johi.
