16 years agoAudio Codec using IC2
I need to project a interface to use the audio codec by using state machines to control it. I am with a big difficulty in founding which address i should use in this protocol to conect with the microfone. Can someone tell me wich address i should use? Thanks!:)6 Replies
Could you please provide more information about the target board and or devices you use for your project ?
Do you use a dev kit or a custom board ? What device is IC2 ? - Altera_Forum
I use the standard kit.
I made a mistake in the name of the protocol The real protocol that should be used is I2C. - Altera_Forum
What standard kit?
The I2C address should be in it's documentation though.. (at this rate, you're going to take a long time to get an answer...) - Altera_Forum
It is altera DE2.
See? That helps a lot.
The address is 0011010 - Altera_Forum
Thx a lot! :)
