16 years agoAudio Codec Problems DE2 Board
Hi, I've been having some problems using the Audio Codec on the DE2 board. I've configured the board using I2C, to use the DAC at 8kHz sampling frequency, 16 bits sample size, to use Left-Justi...
16 years agoPerhaps you have an endianess issue with the data from the WAV file? A WAV file is usually little endian.
