14 years agoarbiterlock on UP IP
Hello, Am Using 11.1 SP2 Quartus and I have problem with UP IPs for example IP pixel_DMA _controller produce error Arbiterlock error, not found. I got some information tells that we need...
13 years ago --- Quote Start --- Hello, Am Using 11.1 SP2 Quartus and I have problem with UP IPs for example IP pixel_DMA _controller produce error Arbiterlock error, not found. I got some information tells that we need to replace arbiterlock by adding burstsignal !!!! How can I do that. Is there 11.1 SP2 version of the UP IPs. Regards --- Quote End --- For now maybe you should work in 11.0 sp1 or an earlier version of that, because in those versions this problem doesn't exists.
