14 years agoAltera Monitoring Program Loading Errors.
Ok, so I have been searching for hours and haven't found anything that sounds similar to my problem. I am using a DE2 Board and am trying to use the DE2_Media_Computer. I am able to open the p...
14 years ago --- Quote Start --- Have you fixed that ? I'm having the same promelem, so may you help me ? --- Quote End --- I never figured out why I was getting that behavior so I just installed it on a different computer and it worked. I know everyone might not have the luxury of having multiple computers so I will tell you this, the only thing that I know that is different in the setups between the non-working install and the working one is that on the computer that didn't work, when I installed the nios 2 and university program software, I put them on a different hard drive than C: so that could have messed with things. FYI, I put them on a different HDD because my boot drive is only 80GB and didn't have enough free space for the install.
