10 years agoAltera Monitor Program resetting and pausing target processor: FAILED
I have a design for a simple NIOS II processor on the DE1-SoC board that assigns the value on the switches to the LEDs (standard hello world) but this design integrates the SDRAM on the board into it...
10 years agoI've seen that message when I had a bad configuration file, or when I forgot to load the FPGA configuration before starting the monitoring program. You can narrow it down by seeing if the board works with a known good configuration file.
