15 years agoAltera Monitor Program nios2-elf-gcc compiler flags
It seems when I try to compile a C program using nios2-elf-gcc in the Altera Monitor Program (v. 11) several compiler flags are added by default. Where are these flags specified and can they be modi...
15 years agoIf you use the new gcc v4 based tools and just eliminate/rewrite any code that is relying on that flag being set that would be the better approach. The newer gcc compilers removed that flag for a reason so if you have the opportunity to remove that code that will make your life easier down the road.
