15 years agoAltera Monitor Program nios2-elf-gcc compiler flags
It seems when I try to compile a C program using nios2-elf-gcc in the Altera Monitor Program (v. 11) several compiler flags are added by default. Where are these flags specified and can they be modi...
15 years agoIt appears to me that the compiler flag causing the issue, "-mno-cache-volatile", is indeed being passed directly to nios2-elf-gcc by the Altera Monitor Program software.
The only solution I could find was to install the Nios II legacy tool located here: https://www.altera.com/download/software/nios-ii The Nios II legacy tool installs GCC3 as well as some other "legacy" software. This eliminates the problem of the "-mno-cache-volatile" parameter by using a version of GCC that still supports it.
