12 years agoAltera Monitor Program Error in Win8
Hi everybody I'm trying to realize a simple project using Altera Monitor Program on a PC with Win8. but when I'm going to compile the C source I receive the following error. 0 [main] ...
11 years agoI too am having this problem but in the NIOS Eclipse tools - though it will all be using the same Cygwin toolset. I tried to use the patch but it doesn't work with Quartus 14 - basically after extracting it as instructed NIOS stops being able to compile the smallc library. I checked the log file and that says something along the lines of "gcc cannot produce executable" (can't remember the exact wording).
Any suggestions?
