17 years agoAltera DE2 Board Not Powering Up Properly
I have 2 DE2 board which does not display the welcome message after it powers up. Looks like it is failing on the Power On Test. Anyone ran into this problem and found a way to "hard" reset these boards?
Thanks in advance.5 Replies
Hi Joelim
Does the "run-prog" switch, is in "run" position ?? Try it. - Altera_Forum
Yes it is. Thanks. - Altera_Forum
The factory configuration may have been overwritten and should be restored from the backup file.
Thanks!
Is there any documentation on how to restore the backup file? - Altera_Forum
Hi Joelim.
In the DE2_UserManual.pdf, chapter 5.1 (5.1 DE2 Factory Configuration) is the decription of how to download the DE2_Default demo. It is simply programming in the DE2_Demonstrations/DE2_Default the .sof file. Regards Alberto.
