13 years agoAlmost Working: USB ISP1362 DE2-115 without NIOS II
I think I'm almost done with this damn thing. I think I can see the light at the end of the tunnel. I'm sure it's just another freight train, though. So, I've interfaced with the ISP1362. ...
13 years agoA few questions for you;
1. How are you configuring the ISP1362 without NIOS II; direct HDL, or JTAG-to-Avalon-MM bridge? Did you check out this project: http://mzakharo.github.io/usb-de2-fpga/ 2. What is your test setup? If you're "cheap", then I'd recommend using Linux and Wireshark. Wireshark can trace USB packets. If you're "not-as-cheap", then do you have a USB "logic analyzer"? I just purchased a Total Phase Beagle 480 USB analyzer ... for another project ... but since I'm the only one using it, I figured I'd play with USB via the ISP1362. I don't have any answers for you yet, but it you want to "share" what you've done, then (if I have time) I'll provide a USB analyzer dump for you :) Cheers, Dave
