16 years agoADV7181B and Clocked input megacore function
Hello could somebody help me? I need to interface the adv7181B (with an YCbCr 4:2:2) with the Clocked Video Input function, but I have no idea about the settings I have to use. I think that i ...
15 years ago@Phate,
May I ask how you have solved this problem? When I use the Test Pattern Generator (YCbCr, 8 bit, 4:2:2, Interlaced, Sequential) I get a correct image on the screen, so all the components between the generator and the VCO are correct. When I attach the TV Decoder, i just get a black (or grey) image, with a correct sync on the screen (well, most of the times). I use the following signals with embedded sync signals: TD_CLK TD_DATA TD_RESET vid_locked and vid_datavalid are tied to VCC. Is this correct? Any help would be appreciated!
