16 years agoADV7181B and Clocked input megacore function
Hello could somebody help me? I need to interface the adv7181B (with an YCbCr 4:2:2) with the Clocked Video Input function, but I have no idea about the settings I have to use. I think that i ...
16 years agoCurrently, I set CVI as 8 bit and embedded sync format.
I've set vid_datavalid as vcc, but all that i get is onle a black screen. So, i've tryed to set CVI as 8 bit and separate sync format, but still, using vid_datavalid as vcc it does't work. Output from the video conerter, in 4:2:2 YCbCr there are only TD_DATA[7..0] TD_HS TD_VS TD_RESET TD_CLOCK (@27MHz) I REALLY don't know how to interface them correctly with the CVI. Any hint wold be precious..
