11 years agoa DE1-SOC + VIP (TPG+VCO) does synthesize but does not simulate
Hi ! I've been designing a very simple design. This is a test, inspired from Terasic's video demo to see how the clock and reset networks are set. This is a TPG connected to the video out c...
11 years agoThank you very much Dave.
Of course, I immediately had a look to all these files for simulation. In the .do file, there was no explicit ref to any alt_vip_common_pkg library to add or file to compile. The compilation error comes from a VHDL file named "alt_vip_cvo_core.sv" at the line 77: it contains a "import alt_vip_common_pkg::*;" The file alt_vip_common_pkg.sv does exists in the same directory than the alt_vip_cvo_core.sv, but it is not included in the .do file for compilation. I added it manually and reran the compilation: it fails when compiling alt_vip_common_pgk.sv because the file is crypted. By the way, this was the opportunity for me to discover this. So, I suppose that there should be somewhere a precompiled version of all these Altera's proprietary (and crypted) files. And I searched everywhere ... (but not in the whole doc yet). Unfortunately, there are no "modelsim" (I mean *.qdb) files about any VIP unit under the Quartus 14.1 installation directory. I suppose these precompiled libs for Modelsim must be obtained somewhere: probably Altera ... I will ask Terasic (the DE1-Soc board makers) how they simulated there VIP demo when debugging it. For sure they did it ! I'll keep the community informed when I have fresh news. If you have any suggestions, do not hesitate. I think I am stuck ... Kind regards, Pierre
