16 years ago128 bit Avalon read/write
Hi, I am working on a class project that uses NIOS II to send 128 bit of data through Avalon bus to a custom logic to process and send back the data through Avalon to NIOS to display. I h...
16 years agoHi,
I actually put this assignment in the code as well assign wr_en_add_1=cs & wr & addr; assign rd_en_add_1=cs & rd & addr; where cs,wr,rd,and addr are mapped to signal chipselect,write, read, and address of avalon in SOPC Builder. The write block above is actually like this always@(posedge clk) begin if (wr_en_add_1) begin if (index==0)begin fifo_in[31:0] <=wr_data; index=1;end //wr_data is to be //map with the write signal of avalon bus, which is the user input signal else if (index==1)begin fifo_in[63:32] <=wr_data; index=2;end else if (index==2)begin fifo_in[95:64] <=wr_data; index=3;end else if (index==3)begin fifo_in[127:96] <=wr_data; index=4;end end After I check with the above code, it seem like the avalon only take the first wr_data from NIOS, an ignore the rest when I want wr_data to have another value to assign to other fifo_in i.e my customer logic only receive fifo_in[31:0] ! Do you have any idea ? Thanks
