16 years ago128 bit Avalon read/write
Hi, I am working on a class project that uses NIOS II to send 128 bit of data through Avalon bus to a custom logic to process and send back the data through Avalon to NIOS to display. I h...
16 years agoIn the code snippet you posted, it does not appear your are checking for the Avalon "write" signal. Your code would attempt to store a word on each clock cycle even when there is no Avalon write taking place.
Personally, I would probably use 2 address bits to split the 128 bit write into four separate 32 bit writes at consecutive word addresses. Then you don't need to keep track of an index manually as in the code you posted.
