16 years ago128 bit Avalon read/write
Hi, I am working on a class project that uses NIOS II to send 128 bit of data through Avalon bus to a custom logic to process and send back the data through Avalon to NIOS to display. I h...
16 years agoThe NIOS II processor only has a 32 bit interface.
So, it will read/write data on 32 bit chunks. The NIOS II i also a master. You need to implement your custom logic as a proper Avalon-MM slave.
