lamweisheng
1 year ago# ** Error: (vcom-7) Failed to open design unit file "output_files/Waveform1.vwf.vht" in read mode.
Hi may i know how am i able to solve this problem
1 Reply
- ShengN_altera
Make sure you have that .vwf.vht file in that path. The .vwf.vht file is auto-generated file and the generation path based on vwf file Simulation -> Simulation Settings -> Testbench Generation Command.
Also, may try to create a new vwf file to get the correct .vwf.vht file path.
Sheng
