sopc-create-header-files appears to have broken on SoC EDS 19.1 under Windows
Hi NBRUN4,
May I ask how did you exactly "add complete path in your script for swinfo2header and all functions" ?
I met the same problem and found your solution, but I don't quite understand it.
Hi Patrick77
Permanent solution:
Go to advanced system settings:
Click on Environment Variables...:
And in "System variables" double click "Path" variable:
And replace the version number in the quortus line (don't forget to change the directory name if youre using a standard quortus version or pro version. Mine is lite):
Another solution:
You need to edit file:
C:\intelFPGA_lite\16.1\quartus\sopc_builder\bin\sopc-create-header-files
You need to edit lines with swinfo2header and sopcinfo2swinfo.
Add:
/cygdrive/c/intelFPGA_lite/16.1/quartus/sopc_builder/bin/
before swinfo2header and sopcinfo2swinfo.
It should be something like this:
/cygdrive/c/intelFPGA_lite/16.1/quartus/sopc_builder/bin/swinfo2header
/cygdrive/c/intelFPGA_lite/16.1/quartus/sopc_builder/bin/sopcinfo2swinfo
Good luck
