malcolm_locke's avatar
malcolm_locke
11 months ago
SD Card Boot
I have an Agilex 5 Modular Development Board which I can boot with the supplied SD Card.
I have tried to update to the latest image at Index of /2025.04/gsrd/agilex5_mk_a5e065bb32aes1_gsrd/,
However, after programming an SD Card with this image, as far as I can tell, my board doesn't boot. I get no output from the serial port so I don't have any way of debugging.
Please can you help with any advice how to proceed to diagnose what is going wrong?
Many thanks
Malcolm
  • Hi Brian,
    It seems like there is a lot of confusion. Maybe it would be helpful for you to start a new thread that clearly states your question(s) and we can try again?
    Sue
    • BrianSune_Froum's avatar
      BrianSune_Froum
      @SueC_Altera
      Quote:
      "Hi,
      Many thanks
      Malcolm"
      According to this quote aka the first comment in this ticket.
      Could you read "no output from the serial port" <-----
      Such behavior is 100% aligned with 2025.01 2025.04 U-Boot Altera github repository on C5 devices.
      I don't see why all stuff comments are so confused on this same issue.
      And I had already explained the issue and the possible solutions accordingly, which might not fix as inherent issue of this early year that Das U-Boot upstream had changed the SPL settings entirely.
      I no expert on Uboot but undergo minor study on such.
      So if there are system Engineer from Altera should know very well.
      • RolandoS_Altera's avatar
        RolandoS_Altera
        Hi Brian
        So you are saying that if you use Altera U-Boot from 2025.01 and 2025.04 branches in Cyclone V, there is no output from the serial console similarly to what is being reported in the Agilex 5 Modular dev kit when using latest branch in Das U-Boot repo?
        If this is the case, I think that for Cyclone V this shouldn't be a surprise, since the latest code validated for Cyclone V uses the QPDS24.1STD_REL_GSRD_PR tag in Altera Repos as it can be seen in https://altera-fpga.github.io/rel-25.1/embedded-designs/cyclone-v/sx/soc/gsrd/ug-gsrd-cve-soc/#source-code
        Cyclone V is aligned with Quartus STD releases, which occur only once a year, so it is not expected to work with U-Boot branches 2025.01 or 2025.04.
        In the case of Modular Dev Kit, this should work with Altera U-Boot branches from 2025.01 and 2025.04, but since not all the updates in the Altera repos have been pushed to the Das U-Boot repo, it possible to observe this issue, so that's why we recommend to use the Altera repo content.
        Rolando
