ainsley26
7 years agoPreloader `make` failed while including include/autoconf.mk.dep
After following the fix here to rectify issues with extracting the tar file containing u-boot; the `make` command to build the pre-loader fails. In particular: ...
make[1]: Entering directory '/cy...
FawazJ_Altera
7 years agoHello,
My apologize for the late reply. I did few tests on SoC EDS, and probably the makefile is not working due to windows update. I will report this to our internal team for a solution.
As a workaround, you can use /usr/bin/make instead of make.
This should be done at the first time on creating preloader. With Uboot, you can use make uboot.
Thank you
- ainsley267 years ago
We actually also had issues with using the /usr/bin/make command as this also failed to compile the preloader. Whilst it appears that it cannot be run on Cygwin, it appears possible with WSL.
Cheers
