preloader make error
I'm trying to do this tutarial
(Host PC: win10 quartus:16.0 SoC EDS:16.0 Developboard:DE10-NANO)
https://bitlog.it/20170820_building_embedded_linux_for_the_terasic_de10-nano.html
when I'm doing "preloader " type "make"
at first i got
*****************************LOG*****************************************************************
tar zxf /cygdrive/c/altera/15.0/embedded/host_tools/altera/preloader/uboot-socfpga.tar.gz
tar: Error opening archive: Failed to open '/cygdrive/c/altera/15.0/embedded/host_tools/altera/preloader/uboot-socfpga.tar.gz'
make: *** [uboot-socfpga/.untar] Error 1
I solved it by looked,
but now I have problem below:
user@DESKTOP-02SRNTM /cygdrive/e/teacher/FPGA/Offitial/DE10-NanoCD/Demonstrations/SoC_FPGA/DE10_NANO_SoC_GHRD/software/spl_bsp
$ make
C:/altera/16.0/embedded/host_tools/cygwin/bin/tar zxf /cygdrive/c/altera/16.0/embedded/host_tools/altera/preloader/uboot-socfpga.tar.gz
‘generated/build.h’ -> ‘uboot-socfpga/board/altera/socfpga/build.h’
‘generated/iocsr_config_cyclone5.c’ -> ‘uboot-socfpga/board/altera/socfpga/iocsr_config_cyclone5.c’
‘generated/iocsr_config_cyclone5.h’ -> ‘uboot-socfpga/board/altera/socfpga/iocsr_config_cyclone5.h’
‘generated/reset_config.h’ -> ‘uboot-socfpga/board/altera/socfpga/reset_config.h’
‘generated/pll_config.h’ -> ‘uboot-socfpga/board/altera/socfpga/pll_config.h’
‘generated/pinmux_config_cyclone5.c’ -> ‘uboot-socfpga/board/altera/socfpga/pinmux_config_cyclone5.c’
‘generated/pinmux_config.h’ -> ‘uboot-socfpga/board/altera/socfpga/pinmux_config.h’
‘generated/sdram/sdram_config.h’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/sdram_config.h’
‘../../hps_isw_handoff/soc_system_hps_0/alt_types.h’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/alt_types.h’
‘../../hps_isw_handoff/soc_system_hps_0/sdram_io.h’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/sdram_io.h’
‘../../hps_isw_handoff/soc_system_hps_0/sequencer_auto_ac_init.c’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/sequencer_auto_ac_init.c’
‘../../hps_isw_handoff/soc_system_hps_0/sequencer_auto.h’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/sequencer_auto.h’
‘../../hps_isw_handoff/soc_system_hps_0/sequencer_auto_inst_init.c’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/sequencer_auto_inst_init.c’
‘../../hps_isw_handoff/soc_system_hps_0/sequencer.c’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/sequencer.c’
‘../../hps_isw_handoff/soc_system_hps_0/sequencer_defines.h’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/sequencer_defines.h’
‘../../hps_isw_handoff/soc_system_hps_0/sequencer.h’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/sequencer.h’
‘../../hps_isw_handoff/soc_system_hps_0/system.h’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/system.h’
‘../../hps_isw_handoff/soc_system_hps_0/tclrpt.c’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/tclrpt.c’
‘../../hps_isw_handoff/soc_system_hps_0/tclrpt.h’ -> ‘uboot-socfpga/board/altera/socfpga/sdram/tclrpt.h’
Applying Patch: C:/altera/16.0/embedded/host_tools/altera/preloader/uboot-socfpga.patch/cygwin/add_fms_extensions_cflag.patch
patch -p1 --directory=uboot-socfpga --input=C:/altera/16.0/embedded/host_tools/altera/preloader/uboot-socfpga.patch/cygwin/add_fms_extensions_cflag.patch
(Stripping trailing CRs from patch; use --binary to disable.)
patching file config.mk
Applying Patch: C:/altera/16.0/embedded/host_tools/altera/preloader/uboot-socfpga.patch/cygwin/apply_mingw_support.patch
patch -p1 --directory=uboot-socfpga --input=C:/altera/16.0/embedded/host_tools/altera/preloader/uboot-socfpga.patch/cygwin/apply_mingw_support.patch
patching file tools/mkenvimage.c
Applying Patch: C:/altera/16.0/embedded/host_tools/altera/preloader/uboot-socfpga.patch/cygwin/build_system_cygpath_repair.patch
patch -p1 --directory=uboot-socfpga --input=C:/altera/16.0/embedded/host_tools/altera/preloader/uboot-socfpga.patch/cygwin/build_system_cygpath_repair.patch
patching file Makefile
Hunk #1 succeeded at 682 (offset 56 lines).
patch: **** Failed to set the timestamps of file Makefile.orig : No such file or directory
Makefile:297: recipe for target 'uboot-socfpga/.applypatch.build_system_cygpath_repair' failed
make: *** [uboot-socfpga/.applypatch.build_system_cygpath_repair] Error 2
any help will be appreciate.
Most user usually refer to Rocketboards guide on the booting which has multiple topics on generating and compiling hardware design, preloader and u-boot etc. You may start here:
https://rocketboards.org/foswiki/Documentation/GSRDPreloader
Also, I am seeing that you are working on Quartus ver 15.0? That is pretty old, I recommended that you refer to above link and follow the guide. And use the 18.1 std version of Quartus and SoC EDS at least.
Let me know if you are still having trouble after following above guide or any questions.
- EBERLAZARE_I_Intel
- ScottShin
thanks, I fix the problem. I unstalled Quartus and soc EDS16.0, then install Quartus18.1 and SoC EDS18.0.
I am glad your issue is fixed, if you have any further questions on other topics , feel free to file a new case/question.
