JJaco16
5 years agoopencl for intel fpga Local memories merging on compilation
I'm trying to implement a piece of code on an arria10 soc development board using openCL. The kernel code has declarations of two local memories as follows
local float __attribute__((memory,...
- 5 years ago
Following the problem about "conflicting memory attributes", you need to set your bankwidth based on your array size. Refer to section 8.4.1 here: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl-best-practices-guide.pdf#page=157
Nurina
JJaco16
5 years agoHi,
Thanks for the answer.
We found out one more way to prevent this from happening. By declaring one memory as local and another as private(since its a single work item kernel, both behave the same). It worked and the compiler doesnt merge them anymore.
