missing hwlib.h: No such file or directory
The complete error message is as follows
$ make
arm-linux-gnueabihf-gcc -g -Wall -Werror -std=c99 -Dsoc_cv_av -I/cygdrive/c/intelFPGA/18.1/embedded/ip/altera/hps/altera_hps/hwlib/include -I/cygdrive/c/intelFPGA/18.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av -I/cygdrive/c/intelFPGA/18.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av/ -c main.c -o main.o
main.c:63:19: fatal error: hwlib.h: No such file or directory
#include "hwlib.h"
compilation terminated.
make: *** [main.o] Error 1
From other forums I found out that including "cygdrive/c/intelFPGA/18.1/embedded/ip/altera/hps/altera_hps/hwlib/include" and "cygdrive/c/intelFPGA/18.1/embedded/ip/altera/hps/altera_hps/hwlib/include/soc_cv_av" should ideally solve the problem. But for some reason I still seem to be getting this error. If I go to this directory and list (ls) the files I can find hwlib.h but somehow the system is unable to do this.
Please help
- AnilErinch_A_Intel
Hi
Please refer to a similar issue below
https://forum.rocketboards.org/t/makefile-error-hwlib-h-no-such-file-or-directory/1966/2
please check whether commands used are properly spaced.
Thanks and Regards
Anil
Hi ,
Please let us know whether the issue has been resolved after updating the commands.
If not you can look in to a similar issue below and use the make file given in the thread to modify to your purposes.
https://community.intel.com/t5/Nios-II-Embedded-Design-Suite/missing-socal-folder/td-p/163375
Thanks and Regards
Anil
Hi ,
Please let us know whether any updates are there about this issue.
Thanks and Regards
Anil
