How to customize the Agilex 7 I-series OS build with SOF and HPS changes ?
Hi
Did you managed to go through the materials shared?
Do you have any follow-up questions?
Jingyang, Teh
- sujan191 year ago
Yes i went through the resource, looking fine till now.
As u previously mentioned that the dts file is in : https://github.com/altera-fpga/linux-socfpga/tree/socfpga-6.12.11-lts/arch/arm64/boot/dts/intelWhich file to be exact, from the resource it seems that its this :
- linux-socfpga/arch/arm64/boot/dts/intel/socfpga_agilex_socdk.dtb
But this is compiled dtb, where is the source of this dtb, And this is only for PS side, if I'm not wrong.
Where is the one for pl for ex: In Xilinx FPGA's its pl.dtsi & system-user.dtsi (for PL to PS conf).Can you let me know the intel equivalent of these dts ?
Sujan- sujan191 year ago
I found this guide for FPGA to HPS bridges for linux : https://altera-fpga.github.io/rel-24.3.1/embedded-designs/agilex-7/f-series/soc/setup-use-bridges/ug-setup-use-bridges-agx7f-soc/
Shouldn't we follow this procedure not the linux boot examples, when our design contain Bridges like msgDMA , pio & interrupts ?
Sujan
