DS-5 Version 2020.1 - Arria 10 EVB baremetal debug - configuration database empty
Hi ,
The target connection information comes from the configuration database which you are using.
Please explore your system and check whether you are able to see the data base files.
use the below link link as a reference on how to add a data base.
Thanks and Regards
Anil
Hello Anil,
Thank you for your update.
I am the distributor embedded FAE working with Tamir.
I followed up with him the directions of ARM, still he is failing to see any platform in the "connection" tab
of the "debug configuration" GUI.
This is what was done so far:
- We located the configdb directory, it looks complete.
- We verified the the preferences of the DS debugger are pointing to this directory.
- We also repeated the procedure to ARM DS 2021.0
Can you advise how to proceed?
Elhanan
