Declarations for UART_MAX_LEN and log_buf (Cyclone V) missing while compiling
I am using 16.0 Version (Quartus, NIOS II SBT, SoC EDS) on Windows. I have tried with latest version 18.1 on Ubuntu 18.04 and Windows as well. All of the them produces the same errors. I have again attached the compiler output screenshot.
I have tried running simple applications, and they are working but I have no clue what's is getting wrong in this project. I just want to setup an HPS and FPGA on Cyclone V DE1-SoC Board with following functions:
-->The HPS must be able to use the LED and button that are directly connected to the HPS PORTION of the device [DE1-SoC Board]. Pressing the button should toggle the LED.
-->The HPS must be able to access the LEDs connected to the FPGA PORTION of the device and will be responsible for creating a strobing light effect on the upper 5 LEDs.
The program is not so long but it uses the printf function. The linker Image file is set to use the "cycloneV-dk-ram-hosted.ld" to access some of the host's functionality to print on the console.
I will be thankful if you can elaborate the function of alt_retarget_gnu.c file. I am not able to find it in the documentation. What is really going wrong in the compilation process??
