BSHAN
5 years agoCyclone V SOC EMAC TX Clk Problem In Linux Kernel 4.x/5.x
Hi All,
We have board designed with Cyclone V SOC and EMAC0 is being used for ethernet interface with RGMII-ID interface .Ethernet interface is working fine with Linux kernel 3.10.I have upgraded l...
EBERLAZARE_I_Intel
5 years agoHi,
You could check how the device tree is between the two kernels, to see if they are any difference between them.
If they are, then you might need to change the config of the device tree accordingly.
