Autogenerated NIOS2 BSP from sopcinfo missing Eclipse project files
Whenever my FPGA design changes I have a shell script that takes the sopcinfo as input and generates a new BSP and runs 'make' on it. That all works fine and and my NIOS2 application builds OK with the generated BSP.
But I would also like to generate the .cproject and .project files in the BSP directory so I can import it into the Eclipse IDE as a useful reference for macros, #defines etc..
I can't find a way to generate these project files using the SBT command line tools or Tcl scipts. Does anyone know how to do this?
Unfortunately, there is no SBT command line tools or tcl available for generating .project and .cproject.
However, you can run nios2-bsp and create-this-bsp to generate full BSP.
- EricMunYew_C_Intel
- TonyH
Thanks for the reply Eric.
I do use the command line tools & Tcl scripts to control the settings and generate the BSP.
I just thought it would be nice to generate the Eclipse project files too. Never mind.
Regards.
