MathiasB
4 years ago[Arria 10SX] Fail to load QSPI flash using quartus_hps
Dear all,
I have a simple design using the HPS on an Arria 10 AS048. The HPS is only present to load the PL configuration at boot time using u-boot.
I generated a .rbf.img and a uboot-mkpimage.b...
aikeu
4 years agoHi MathiasB,
I am not sure how you get/generate your boot image in the first place or documents that you refer to build your project.
Normally I use the gsrd as the base for my project build, so better try to test with a default gsrd version first.
You can try peform the QSPI flashing with quartus_hps cmd using the working gsrd example and see any difference from the outcome.
You can also find some of the prebuild gsrd in the link below:
https://releases.rocketboards.org/release/
Aik Eu
