[Arria 10SX] Fail to load QSPI flash using quartus_hps
Thank you for the link.
However, I am a bit lost here. Since i am using Quartus pro 19.1, there seems to be differences with what is presented in the link.
For instance, when I run make to build u-boot, I do not have any "spl/u-boot-splx4.sfp". Also, I do not have this "board/altera/arria10-socdk/fit_spl_fpga.its" file for mkimage.
I tried again earlier and for some reason I managed to successfully run "quartus_hps -c 1 -o P -a 0x0 uboot-mkpimage.bin" (I did not verify if it *truly* worked, though). I had to try several times the same command before that.
Now I am trying to run "quartus_hps -c 1 -o P -a 0x720000 pl.rbf.img", but it fails just like shown in the image attached to my first message.
Do you think the type of file I am using is the cause?
Since the "percentage of loading" at which quartus_hps is never the same, I would guess it has something to do with an unreliable state of the HPS. Does the HPS have to be in a particular state (if that makes sense) for quartus_hps to run?
