TBaox
5 years agoARM A9 bare matal IRQ priority can't work
I use cyclone V HPS, and there is a problem in configuring interrupt priority. I gave OSC1 TIMER a higher priority, and after the program was executed, I found that it could not preempt the low prior...
EBERLAZARE_I_Intel
5 years agoHi,
Is the timer interrupt that you mentioned also could not run normal if if interrupt from other sources other than FPGA?
- TBaox5 years ago
I didn't try that.
But IRQ from FPGA timer ip doesn't preempt the low priority external interrupt from FPGA pio,too.
So I think something wrong on my configation.
