12 years agoZero Packed Or Unpacked Array Dimensions Problems
Hi bros. I want to implement a circuit that run like this:
- If reset = 0, the output data = 12'b0; - If not, the output data = a vector in the ROM. And this is my code (I apologize for its length, but you can ignore what is in the concatenation operator) module ROM_sin ( input clk, rst, input [10:0] addr, output reg [11:0] data ); reg [10:0] temp; integer i; reg [11:0] RAM_2048_12BIT [2047:0]; assign MY_ROM = {12'b000000000000, 12'b000000000110, /* lots of values here */ , 12'b111111111001}; always @ (posedge clk or negedge rst) begin for (i = 0; i <= 2047; i = i + 1) begin assign RAM_2048_12BIT[11:0] = my_rom[11:0]; end if (!rst) data <= 12'b0; else if(clk) begin temp[10:0] = addr; data = RAM_2048_12BIT[temp]; end end endmodule And when I compiled it, I got an error: "Error (10053): Verilog HDL error at rom_sin.v(274): can't index object "MY_ROM" with zero packed or unpacked array dimensions" Please tell me why this error occurs and how to fix it. Thank you so much!
