Altera_ForumHonored Contributor13 years agoXilinx to Altera "DATAPATHONLY" Constraint I'm converting an Xilinx to Altera and I'm hitting a wall on the following timing constraint. Does Altera have a "DATAPAHTONLY" constraint? NET "clk_125" TNM_NET = FFS "GRP_A"; NET "clk...Show More
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
