12 years agoXCVR TK STRATIX V issue
Hello
I am using the transceiver toolkit (XCVR TK) for analyzing a transciever channel between ARRIA V and STRATIX V FPGA's . The data rate is within both FPGA's range (~2Gbps).- when i use the basic mode- there is no problem. I can easily control both transceiver sider (Rx and Tx) and change the parameters manually, see the BER, ect. and it is even make sense :rolleyes:
- Whenever I try to switch to the advanced mode in order to run Autosweep OR EYEQ - It won't work.:cry:
