8 years agowriting and reading the same pipe in one kernel
Hi I want to write and read the same pipe in one kernel like this: channel float c0 __attribute__((depth(2))); __kernel void testkernel() { for(int i = 0; i < n; i ++){ page_ra...
8 years ago --- Quote Start --- Are you unrolling your loops? Post your complete kernel since the snippet you have posted should compile correctly. --- Quote End --- Below is my kernel code: # define M 100 channel float c0 __attribute__((depth(2))); __kernel void mapreduce_page_rank(__global float* restrict page_ranks, int n, const __global int* restrict pages, const __global unsigned int* restrict noutlinks){ int i, j, t; float new_rank; float d_factor = 0.85; float cur; float maps; float outbound_rank; float new_rank_copies[M]; # pragma unroll for (i = 0; i < M; i ++){ new_rank_copies = 0;
for(i=0; i<n; ++i){
new_rank = 0.0;
for(j=0; j<n; ++j){
outbound_rank = page_ranks[j] / (double)noutlinks[j];
maps = pages[i*n+j] * outbound_rank;
cur = new_rank_copies[m-1] + maps;
# pragma unroll
for(int c = m-1; c > 0; c--){
new_rank_copies[c] = new_rank_copies[c - 1];
new_rank_copies[0] = cur;
# pragma unroll
for(int j = 0; j < m; j ++){
new_rank += new_rank_copies[j];
new_rank_copies[j] = 0;
new_rank = ((1-d_factor)/n)+(d_factor*new_rank);
write_channel_altera(c0, new_rank);
__kernel void produce_page_rank(__global float* restrict page_ranks,
int n,
int i, j, t;
float new_rank;
float cur;
float maps;
float new_rank_copies[m];
# pragma unroll
for (i = 0; i < m; i ++){
new_rank_copies = 0; } for(int i = 0; i < n; i ++){ page_ranks[i] = read_channel_altera(c0); } for(i=0; i<n; ++i){ new_rank = 0.0; for(j=0; j<n; ++j){ outbound_rank = page_ranks[j] / (double)noutlinks[j]; maps = pages[i*n+j] * outbound_rank; cur = new_rank_copies[M-1] + maps; # pragma unroll for(int c = M-1; c > 0; c--){ new_rank_copies[c] = new_rank_copies[c - 1]; } new_rank_copies[0] = cur; } # pragma unroll for(int j = 0; j < M; j ++){ new_rank += new_rank_copies[j]; new_rank_copies[j] = 0; } new_rank = ((1-d_factor)/n)+(d_factor*new_rank); write_channel_altera(c0, new_rank); } }
