--- Quote Start ---
Thank you for your answer,but you can see that the source clock obviously faster than destination clock,which would lead to data lose in the practial desgin.
Would you tell me the use of the timing?
--- Quote End ---
the clocks have a fix ratio of 10ns/8ns. That means you will have a finite number of phase relations of the clocks. That are excatly the four you see in the picture. After that the pattern starts again.
10 20 30 40 destination clock
8 16 24 32 40 source clock
After 40 ns the pattern starts again !
Kind regards
GPK
