Whitebird,
I have often had this problem as well and until now, I was simply adding an output pin to the node I wanted to probe out. This way is the easiest one but have several drawbacks: lack of flexibility and above all, it can drasticaly change your timing performances. In fact, with additionnal output pins, the routing and fitting within the device can significantly be different from the same project wo/ those "probing" ouptut pins . This remarks apply to timing simulations only.
Regarding functional simulations, nodes that are not connected to an input/output pin have their name either changed or downright supressed after synthesis ("synthesised away"). There are several logic options that can help you:
1)Synthesis Logic Options: "Implement as Ouput of Logic Cell", "Preserve Registers", "Preserve Fan-out Free Register Node".
2)Simulations Logic Options: "Add D and Q Ports of Register Node to Simulation Output Waveforms","Add to Simulation Output Waveforms".
Depending on the type of signal you'd like to view (combinational output or register output), one or several of the above options can apply but the very first condition to use them is to apply them to a nodename known from the Analysis & Synthesis module: this is the point where it becomes a tricky business !...As the Qts II Help and Handbook are not very clear about this topic (see Vol.1/Chapt.7"QuartusII Integrated Synthesis"/"Node Naming Conventions", I just can tell you to find in your neighborhood a Qts II experimented user that will help to clarify this problem "in live and on the screen" or to convince your boss to pay you for an ALTERA training.
A last remark: I think it's a pity that the node finder lists nodes that the simulator can't view ! May god or ALTERA change this a day...
Let me know if you find the key of that problem which is part of the "Frequently Asked Questions" of this forum. It will help many QtsII users for sure !
Oliver
