12 years agoWorking with Multiple QSF files
I'm developing a board suppport package that I can use for multiple applications that are built for the same part. I currently have two applications that use common top-level RTL, but they have indiv...
12 years agoStrange. Definitely file a Service Request, as I don't think that is correct behavior.
I assume that particular verilog file isn't in the added supplemental .qsf? Also note that for the pre-flow scripts that I don't use export_assignments. I'm not saying that's a problem, nor that it will fix it, as I don't remember using a pre-flow script in conjunction with secondary .qsf files, but maybe one more thing to try. But yes, sounds like a bug. Bet you banged your head on the table a few times having to debug that.
