12 years agoWorking with Multiple QSF files
I'm developing a board suppport package that I can use for multiple applications that are built for the same part. I currently have two applications that use common top-level RTL, but they have indiv...
12 years agoThe issue appears to be with using specific commands in the pre-flow script in addition to multiple QSF files. I tried modifying the a5gt_golden_top design for FPGA2 provided in the Arria V GT Development Kit SDK. If I move some of the QSF assignments to a separate file and add "source separate_file.qsf" to a5gt_golden_top.qsf, everything works as billed in the documentation. cool. However, if I add a pre-flow script that removes all source code, I get the error message saying that the QSF file has errors. I'll illustrate.
Working pre-flow script:project_open a5gt_golden_top.qpf
set_global_assignment -name VERILOG_FILE a5gt_golden_top.v
export_assignments
project_close Failing pre-flow script: project_open a5gt_golden_top.qpf
remove_all_global_assignments -name VERILOG_FILE
export_assignments
project_close I've tried a variety of permutations with the code in this script, and the only thing that matters is if I remove all source code. I'm feeling like this is a bug in the toolchain, but I'm far from an expert on Quartus.
