--- Quote Start ---
can you explain the problem more detailed ? Maybe you can post the schematic, which shows the effekt you don't want ?
Kind regards
GPK
--- Quote End ---
There you go, this is a block diagram. If you move the horizontal line two times up with the keyboard arrow, it'll stick to the lead of the vertical line.
At this point both lines stay joined no matter how I move the horizontal one.
Again it's extremely annoying. You could heard people swearing in the University course last weak cause of this when working on an homework.
We just switched of circuit designer software and we're not used to Quartus II.
