16 years agoWindows7-64 Bit
Hi all,
I have installed the Quartus II Web edition on Windows7. But it seems that I need for Byteblaster a special driver. Can anybody help me?Hi all,
I have installed the Quartus II Web edition on Windows7. But it seems that I need for Byteblaster a special driver. Can anybody help me?Hi,Heinrich
I have the same problem as yours , it nearly made me crazy! Do you get the problem sovled? Thank you very much if you can answer me . canny_cc.Try opening going to control panel and opening up the device manager. The byteblaster should be there but with a yellow "problem" symbol. Right click to update the driver and choose manual update. Navigate into your altera directory for 10.1sp1 or whatever you have, then to quartus/drivers/usb-blaster. Select that as the driver location and the driver should install properly.
DavidThank you very much!
