8 years agoWindows 7 T-Guard driver for MaxplusII 10.2 required
I need to re-use an old design and show I can recompile,place and route the old code. The design was produced under Max plus II V10.2, I have the parallel port dongle and a copy of Max Plus II 10.2. The issue is getting Maxplus II to see the dongle and also producing the licence file. Any pointers on both would be appreciated. Thanks3 Replies
Wow, if it's HDL code, can't you just bring it in to Quartus instead?
--- Quote Start --- Wow, if it's HDL code, can't you just bring it in to Quartus instead? --- Quote End --- Does Quartus do Max9000? - Altera_Forum
If you can send me your project, I can try to compile it and in case of success we could continue our discussion )
