13 years agoWhy the type converter does not work ?
In my design I need to do is convert a std_logic_vector signal to the integer signal for array index. Then I do following:
" use IEEE.NUMERIC_STD.ALL; generic ( C_SLV_ADWIDTH : integer := 6; -- This width is actual address width ) constant C_NUM_REG : integer := 2 ** C_SLV_ADWIDTH; signal slv_addr : std_logic_vector(C_SLV_ADWIDTH-1 downto 0); signal slv_addr_integer : integer range 0 to C_NUM_REG; slv_addr_integer <= to_Integer(slv_addr); -- this convert data type std_logic_vector to integer " But I get errors, why converter does not work? Thanks in advance.
