11 years agoWhy the output of this Code is 'U' ?
Hi all
Why the Sum Value is 'U' in this code ? :
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY Adder_4_Bit_2C IS
PORT(
A, B : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
Mode : IN STD_LOGIC;
Sum : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
AVF : OUT STD_LOGIC
END Adder_4_Bit_2C;
ARCHITECTURE Structure OF Adder_4_Bit_2C IS
COMPONENT FullAdder_1_Bit IS
PORT(
X, Y : IN STD_LOGIC;
CIn : IN STD_LOGIC;
FSum : OUT STD_LOGIC;
COut : OUT STD_LOGIC
END COMPONENT;
COMPONENT XORGate IS
PORT(
X1, X2 : IN STD_LOGIC;
Y : OUT STD_LOGIC
END COMPONENT;
SIGNAL COut_Temp : STD_LOGIC_VECTOR(3 DOWNTO 0);
SIGNAL XB : STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
B_0 : XORGate PORT MAP(Mode, B(0), XB(0));
B_1 : XORGate PORT MAP(Mode, B(1), XB(1));
B_2 : XORGate PORT MAP(Mode, B(2), XB(2));
B_3 : XORGate PORT MAP(Mode, B(3), XB(3));
SUM_0 : FullAdder_1_Bit
PORT MAP (A(0), XB(0), Mode, Sum(0), COut_Temp(0));
SUM_1 : FullAdder_1_Bit
PORT MAP (A(1), XB(1), COut_Temp(0), Sum(1), COut_Temp(1));
SUM_2 : FullAdder_1_Bit
PORT MAP (A(2), XB(2), COut_Temp(1), Sum(2), COut_Temp(2));
SUM_3 : FullAdder_1_Bit
PORT MAP (A(3), XB(3), COut_Temp(2), Sum(3), COut_Temp(3));
AVF_COut : XORGate PORT MAP(COut_Temp(2), COut_Temp(3), AVF);
END;
Sum , COut_Temp and AVF are 'U' ! , why ?!? I Simulated this code with Model-Sim and Forced values of A, B and M but all Outputs are 'U' ! thanks ...3 Replies
'U' implies they are uninitialised - ie. they have not yet been assigned a value.
Trace back the connections to see why. - Altera_Forum
That is Output and mapped to Out port of adder , when A and B and Mode have value , Sum should have value too , Is it correct ?!
I have tested that and Sum shown Output , then I closed project and opened another project with Model-Sim , And Opened this project again and now there is no output ! - Altera_Forum
You haven't posted the adder code, nor the test bench code, so I have no idea what should happen. Did you actually run the simulation?
